CINCINNATI AROW 500 ACRAMATIC 2100 BŁĄD NCA SIMODRIVE 611 POWER MODULE FAULT
: 30 mar 2018, 12:41
WITAM
MAM PROBLEM Z FREZARKĄ CNC CINCINNATI AROW 500 Z STEROWANIEM ACRAMATIC 2100. WYSKOCZYŁ MI BŁĄD NCA SIMODRIVE 611 POWER MODULE FAULT (ZDJĘCIE NA DOLE),MOŻE KTOŚ MIAŁ PODOBNĄ SYTUACJE LUB WIE GDZIE SZUKAĆ USTERKI. SPRAWDZIŁEM ZASILACZ SIMODRIVE, NAPIĘCIE JEST OK(DIODY PALA SIĘ NA ZIELONO), FALOWNIK OK (RUN). Z GÓRY DZIĘKUJE ZA POMOC.MOŻE ZNAJDZIE SIĘ OSOBA Z OKOLIC JELENIEJ GÓRY KTÓRA ZNA SIĘ NA RZECZY.
POZDRAWIAM ŁUKASZ KOSIOR
533161110
533161110
