Czy macie może pomysły co z tym zrobić ?
PS. Przy wyłączaniu NX po sprawdzeniu czy moduł Manufacturing działa pojawia mi się error " Initial error: memory access violation "
Kod: Zaznacz cały
&MACRO FOCUS CHANGE IN 1
&MACRO MENU, 0, UG_APP_MANUFACTURING UG_GATEWAY_MAIN_MENUBAR ! <MB/Toolbar>
Successfully loaded dynamic module D:\NX8\UGII\libcamsint.dll
Loaded module C:\Windows\system32\Msftedit.dll 7fef55b0000 c6000 dba53a9a-4760007f-65537b84-164d05fa-2 version = 5.41.21.2510
Loaded module C:\Windows\system32\RICHED20.DLL 7fed7780000 9e000 6fdbe42a-433b21f5-3eba7997-98b72857-2 version = 5.31.23.1230
*** EXCEPTION: Error code 1990004 in line 1005 of O:\ugnx803\ip4\src\cams\no\ind\cam_session_definitions.c at Wed Jan 09 18:38:26 2013 Środkowoeuropejski czas stand.
+++ Invalid file name: $UGII_CAM_CONFIG
[ 1] 07FEFDC09E5D (KERNELBASE)
[ 2] 07FEEEEFFB2E (libsyss)
[ 3] 07FEEEF338BD (libsyss)
[ 4] 07FEEEF33D60 (libsyss)
[ 5] 07FEEEF34D77 (libsyss)
[ 6] 07FEEEF34F42 (libsyss)
[ 7] 07FEEEEFA0AC (libsyss)
[ 8] 07FEEEEFA869 (libsyss)
[ 9] 07FEDF3F515D (libcams)
[10] 07FEDF3F3A0F (libcams)
[11] 07FEDF3DFDD1 (libcams)
[12] 07FEE8DDC47D (libpart)
[13] 07FEDA9813E6 (libcamsint)
[14] 07FEDA57848E (libugui)
[15] 07FEDA57868A (libugui)
[16] 07FEDC65FFEE (libuginitint)
[17] 07FEDA41AF9D (libugui)
[18] 07FEDA41B8AC (libugui)
[19] 07FEDA41B9CC (libugui)
[20] 07FEDA41BA6F (libugui)
[21] 07FEDA41BAAE (libugui)
[22] 07FEDA42351E (libugui)
[23] 000000569499 (windowsui)
[24] 000000566B40 (windowsui)
[25] 0000002F15C6 (ugtbxm)
[26] 0000002E3FF3 (ugtbxm)
[27] 0000002E54D5 (ugtbxm)
[28] 00006C00E608 (mfc100u)
[29] 00006C00E08C (mfc100u)
[30] 00006C00B8DD (mfc100u)
[31] 00006C00BC84 (mfc100u)
[32] 00006BEC01C7 (mfc100u)
[33] 000076D79BD1 (USER32)
[34] 000076D798DA (USER32)
[35] 00006BFF50CA (mfc100u)
[36] 0000005CCEB0 (windowsui)
[37] 0000005CE803 (windowsui)
[38] 0000005CE933 (windowsui)
[39] 07FEDA38DB70 (libugui)
[40] 07FEDA577927 (libugui)
[41] 07FEDA52CF01 (libugui)
[42] 07FED7CBCB68 (libmodlint)
[43] 07FEDC63816D (libuginitint)
[44] 0001400032B1 (ugraf)
[45] 000140001F82 (ugraf)
[46] 000140006D12 (ugraf)
[47] 000076E7652D (kernel32)
[48] 00007746C521 (ntdll)
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\cams\no\ind\cam_session_definitions.c" at line number 1012
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\cams\no\ind\cam_session.c" at line number 348
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\drv\part\no\ind\ja_session_jam.cxx" at line number 1862
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\ugui\no\ind\mb_callbacks.c" at line number 1834
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\ugui\no\ind\mb_menubar.c" at line number 1544
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\ugui\no\ind\uigblfunc.c" at line number 275
>>>> Error code 1990004 caught in file "O:\ugnx803\ip4\src\modlint\no\ind\ui_modl_app.cxx" at line number 462
&MACRO WINDOW RESIZE 1.000000 13.947917 6.687500 -1.000000 -0.479462 1.000000 0.479462
&MACRO MESSAGE_BOX -2, Error recovery completed for the following error:
&MACRO MESSAGE_TEXT Invalid configuration file.
&MACRO FOCUS CHANGE OUT 1
&MACRO MENU, 0, UG_LWIN_FILE_EXIT ListingWindowMenuBar !
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR ! <MB/Toolbar>
