Mam komunikat jak w temacie, podczas wywołania funkcji spreadsheet.
Wydaje mi sie ze powstało to z update excell do wersji 2007
ma ktos pojecie jak to naprawić??
log:
default spreadsheet version installed on this machine is Excel 2007 Spreadsheet
starting new Spreadsheet using file C:\Users\DOCUME~1\LOCALS~1\Temp\ugx126.tmp
Failed to create excel workbook with error code 14007
ERROR: starting excel failed with code 80040154
zdrówko
filed to create new excel workbook
marcinello3
marcinello3
nxcam
U mnie nie mam problemów z NX 6.0 i Office 2007...
- poszperałem na forach o N 6.0 znalazło się jednak co nieco na ten temat
- poniżej przykładowe rozwiązania:
I.
Double clicking the ug.xla file in the /ugii folder launches Excel.
II.
The issue can be worked around by modifying a Windows Registry entry as follows:
1) Take a complete back up of Windows registry
2) Make sure, HKEY_Local_Machine\Software\Wow6432Node\Classes\CLSID\00020820-0000-0000-C000-000000000046 exists.(If this key doesn't exist, there could be an issue with the installation)
3) If the key exists, then locate, select and delete the following key:HKEY_Local_Machine\Software\Classes\CLSID\00020820-0000-0000-C000-000000000046 . Please note this workaround is only for the 64 bit Windows systems having only Excel 2003 as the default spreadsheet application. Before modifying the registry, make sure you have a full backup of your system. If anything goes wrong, you may end up losing all your data and need to reinstall Windows.
III.
The problem where the NX Spreadsheet failed to start reporting: "Failed to create new Excel workbook", is fixed after upgrading Excel to version 2010.
Tłumaczenie:
This PR reported that it is not possible to launch an Excel spreadsheet within 64-bit NX6 installed on 64-bit Windows 7.
Excel 2003 was released when 32bit OS were the standard and Excel 2003 is a 32-bit application. With the 64-bit OS Microsoft delivered WoW (Windows over Windows), so that 32-bit applications could run on 64-bit Window OS as if they were running on 32-bit Windows OS.
This WoW needs registry entries to be created properly on 64bit OS, generally referred to as "6432node" in the registry. With Excel 2003 these entries were missing, however Microsoft has fixed these issues with Excel 2007 and Excel 2010.
To make it work "6432node" registry entries need to be recreated on the concerned OS, which should have been resolved by Microsoft, however, the support for Excel 2003 is very limited due to availability of two upgraded releases.
The workaround would be to upgrade to Excel2007 or Excel2010.
I.
II.
III.
Tłumaczenie:
marcinello3
