Czy na tym pójdzie NX7.5
: 25 mar 2011, 10:49
autor: kubuuss
Czy na pentium IV 1200 Hz, 500 ram, karta graficzna popularna pójdzie NX 7.5 do nauki. UG18 w zupełnie dobrze sobie na tym sprzecie radził oprócz złożeń.
: 25 mar 2011, 20:10
autor: SACZI
Uruchomić, uruchomisz, ale nic nie zrobisz.
Na Sempronie 1,67 GHz, 512 MB RAM i Radeonie 9550 NX5 nie chce działać ze złożeniem z kilkunastu plików.
: 26 mar 2011, 10:53
autor: nxcam
- na tym pójdzie do kościoła swojego i może uklęknie na jedno kolano ewentualnie zegnie plecy, albo mu szyja lekko tyknie
Graphics adapters
All the NX certified systems contain graphics adapters that meet all Siemens PLM Software requirements and are fully supported by our hardware partners. The graphics adapters supported are carefully selected by working with our OEM partners as well as our graphics vendor partners. We do not support low-end, consumer or game cards, since these graphics devices are developed for the DirectX market and are not well supported under OpenGL. Because a majority of platform/hardware problems are graphics related, it is critical that all the graphics adapters that NX supports are designed for OpenGL and have the highest level of support from our hardware vendors. We highly recommend that customers only use supported graphics adapters and Siemens PLM Software certified drivers.
Graphics adapters that are not recommended for use with NX, because they are considered mainstream/enthusiast cards used by home/office/gamer markets, include:
nVidia: GeForce, nForce, and Quadro NVS
ATI: Radeon
Customers running Microsoft Windows 7 or Vista will require graphics adapters with more on-board memory, especially when AERO (the enhanced 3D feature) is turned on. The minimum recommended graphics on-board memory is 256MB, and although graphics adapters with less memory will work, the performance may not be adequate, even with AERO turned off. Customers with high-end graphics requirements will need to consider graphics adapters with 512MB or higher on-board memory. ..."
: 01 kwie 2011, 00:08
autor: segama
Ja mam Acer Aspire 6920G, processor 2.0 duo, 3gb ram, Ati Radeon 3650 512mb up to 2gb
I ci powiem ze jak mialem zainstalowana viste to przy wiekszych modelach sprzet mulił. Jak najezdzales myszka na model to potrzebowal kilku sekund na odswierzenie, albo trzeba bylo pracowac na wireframe. Jak zainstalowalem XP to pomoglo - przyspieszylo prace. Aha i ja mam NX6.0
Zeby sie na NX ladnie pracowalo to potrzeba dobrego sprzetu - chce kupic cos ale nie wiem jeszcze co. A czy ktos probowal odpalic NX 6.0 na windows 7 ??? jak to chodzi i jaki macie sprzet???
: 02 kwie 2011, 10:41
autor: Lukas.s
Ja pracuje na:
core 2 duo 2x3.00GHZ
2 GB RAMU
Grafika zintegrowana GMA3100
WIN XP
I śmiga jak ta lala, trochę przycina jak wczytuję złożenia form.
: 02 kwie 2011, 10:55
autor: SACZI
Lukas.s, na integrze formy wczytujesz?
: 05 kwie 2011, 06:52
autor: Lukas.s
jak nie mam wyjścia to tak, ale zazwyczaj robię to w celu sprawdzenia czegoś bo pracować nie da się. Jak coś nie idzie to jest jeszcze jeden komp:
-Procesor i7 2.80
-4GB RAMU
-Nvidia quadro fx 580
-Win 7 64bit
Temu nic nie brakuje :roll:
: 11 kwie 2011, 22:18
autor: SACZI
Lukas.s pisze:jak nie mam wyjścia to tak, ale zazwyczaj robię to w celu sprawdzenia czegoś bo pracować nie da się. Jak coś nie idzie to jest jeszcze jeden komp:
-Procesor i7 2.80
-4GB RAMU
-Win 7 64bit
Ja mam dokładnie taka samą stacyjkę z tym, że Windows XP 32b na nim pracuje.
Mam wrażenie, że ... komputer jest słaby ...
: 12 kwie 2011, 00:13
autor: tumanek
Tak z tymi wymaganiami bym nie przesadzał
fakt "lepiej jak jest więcej" ale mi na radeonie starym (nawet nie wiem jakim - za 400 pln 2 lata temu) chodza zlozenia lepiej niz na dell 3400 (quadro jakaś średnia polka).
a o obrobce to nawet nie wspomne:)
a poza tym - aczkolwiek to sie zmienia - ug najbardziej zoptymalizowany systemem jest:)
pozdrawiam
: 15 paź 2012, 15:54
autor: lionek
Wiem, że troche odświeżam temat ale chciałbym się zapytać, czy NX7.5 pójdzie na takim sprzęcie
MSI GX-740
Intel Core i5-460M 2.53GHz
ATI Radeon HD Mobility 5870 /1GB DDR5
4GB RAM DDR3
Windows Home Premium 64bit
