Mam problem z okrąla kieszenia , wyskakuje błąd RADIUS COMP. UNDEFINED
oto programik w jakim to chcę zrobić:
proszę o pomoc co jest nie tak
0 BEGIN 111 PGM MM
1 BLK FORM 0.1 Z X+0 Y+0 Z-20
2 BLK FORM 0.2 X+100 Y+100 Z+0
3 TOOL DEF 1 L+0 R+5
4 TOOL CALL 1 S1000
5 CYCL DEF.5.0 CIRCURAL POCKET
6 == 5.1 SET-UP -2
7 == 5.2 DEPTH -5
8 == 5.3 PECK -3
9 == 5.4 RADIUS 35
10 == 5.5 F100 DR-
11 L Z+100 R0 FMAX M6
12 LX+60 Y+50 FMAX M3
13 LZ+2 FMAX M99
14 LZ+100 FMAX M2
15 END PGM 111MM
PROSZE O POMOC DLACZEGO TAK SIE DZIEJE, PROGRAM ZJEZDZA NA POZYCJE STARTOWA TZN 60, 50 I WYSKAKUJE TEN BLAD. I PROGRAM STOI.
[ Dodano: 2009-02-17, 17:42 ]
JEST TO HEIDENHAIN 360R
cykl 5.0 w Heidenhain 360 problem
Sproboj tak-
1 BLOK FORM X-200 Y-200 Z-10
2 BLOK FORM X+200 Y+200 Z+2
3 STOP M6
4 TOOL CALL 1 S1000
6 == 5.1 SET-UP -2
7 == 5.2 DEPTH -5
8 == 5.3 PECK -3
9 == 5.4 RADIUS 35
10 == 5.5 F100 DR-
13 LZ+2 FMAX M99
14 LZ+100 FMAX M2
Moze to cos pomoze.
W tabeli narzedzi masz mniejszego freza wpisanego?
3 STOP M6
4 TOOL CALL 1 S1000
6 == 5.1 SET-UP -2
7 == 5.2 DEPTH -5
8 == 5.3 PECK -3
9 == 5.4 RADIUS 35
10 == 5.5 F100 DR-
13 LZ+2 FMAX M99
14 LZ+100 FMAX M2
Moze to cos pomoze.
witam
zrub może tak
0 BEGIN 111 PGM MM
4 TOOL CALL 1 S1000
5LZ+100 RO FMAX M6
6LZ+2 FMAX
7LX+60 Y=50 R0 FMAX
8 CYCL DEF.5.0 CIRCURAL POCKET
9 == 5.1 SET-UP -2
10 == 5.2 DEPTH -5
11 == 5.3 PECK -3
12 == 5.4 RADIUS 35
13 == 5.5 F100 DR-
14 CYKLE CAL M3
14 LZ+100 FMAX M2
15 END PGM 111MM
zrub może tak
0 BEGIN 111 PGM MM
4 TOOL CALL 1 S1000
5LZ+100 RO FMAX M6
6LZ+2 FMAX
7LX+60 Y=50 R0 FMAX
9 == 5.1 SET-UP -2
10 == 5.2 DEPTH -5
11 == 5.3 PECK -3
12 == 5.4 RADIUS 35
13 == 5.5 F100 DR-
14 CYKLE CAL M3
14 LZ+100 FMAX M2
15 END PGM 111MM
