Morbidelli U50
Dyskusje o maszynach Morbidelli
avanu_cristi
Morbidelli U50
Post napisał: avanu_cristi » 18 lip 2017, 20:58
Hello
Sorry , i speak only english.
I have a Morbidelli u50 for 2 monts , now i have start it , for most of things works ok , but i have a problem , if i go whith the speed over 50% i have the next error :27 X Axis:pursiut erorr
can anyone help me pls !
Petroholic
Post napisał: Petroholic » 18 lip 2017, 21:34
X AXIS maximum speed 20.000 ??? That gives 20m/min it's way to fast in my opinion. Google says it should be less...
From the other post about same problem:
Next thing is - check X axis screw if it's clogged...
avanu_cristi
Post napisał: avanu_cristi » 19 lip 2017, 09:01
Hello , i have seen that post , but if i put the values like in the picture you put , and the speed is to low .
At the begining it worked mutch faster , but like most of the people, the baterry run out and lost the parameters , i loaded the new ones and have this problem now.
and if i put the values from the picture only in x axis , then i have same erorr but in the next axis , Y , and so on
So i think is a problem whith the parameters.
Tnks!
[ Dodano: 2017-07-19, 11:50 ]
Petroholic pisze:X AXIS maximum speed 20.000 ??? That gives 20m/min it's way to fast in my opinion. Google says it should be less...
On everithing i found on google the specification looks like in the picture atach
Petroholic
Post napisał: Petroholic » 19 lip 2017, 22:09
Settings in your attachment says nothing about maximum axis speed...
It says ACCELERATION RAMP not speed...
But acceleration ramp means time that machine takes to gain maximum speed from stall...
Strange that it says "m/sec" ?
jarosław pawlik
Post napisał: jarosław pawlik » 21 lip 2017, 22:52
Replace the brushes on the engine .
Wróć do „Morbidelli”
