Zmiana w Journal-u
NX CAM/Unigraphics
devon58
Zmiana w Journal-u
Post napisał: devon58 » 01 sty 2016, 22:37
Witam, w sieci znalazłem bardzo przydatny dla mnie journal ale chciałbym wprowadzić drobną zmianę niestety kompletnie nie znam się na VB.
Journal kopiuje do schowka współrzedne punktu jednak robi to w jeden lini a chciałbym aby współrzędne znajdowały się jedna pod drugą
Kod: Zaznacz cały
April 3, 2014
'select points on screen, copy information to clipboard
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim theUfSession As UFSession = UFSession.GetUFSession
        If IsNothing(theSession.Parts.Work) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim pointValues As New List(Of String)
        Dim response1 As Integer = Nothing
        Dim mode1() As Integer = {0, 0}
        Dim pointDisplayMode As Integer = 0
        Dim objectpoint(2) As Double
        Do
            theUfSession.Ui.LockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
            response1 = theUfSession.Ui.PointSubfunction("Select Point", mode1, pointDisplayMode, objectpoint)
            theUfSession.Ui.UnlockUgAccess(NXOpen.UF.UFConstants.UF_UI_FROM_CUSTOM)
            If response1 = 5 Then
                Dim myPtVal As String = "X = " & objectpoint(0).ToString("N2") & " Y = " & objectpoint(1).ToString("N2") & " Z = " & objectpoint(2).ToString("N2")
            If pointValues.Contains(myPtVal) Then
                    Exit Do
                Else
                    pointValues.Add(myPtVal)
                End If
            End If
        Loop Until response1 <> 5
        Dim myStringBuilder As New Text.StringBuilder
        For Each pt As String In pointValues
            myStringBuilder.Append(pt)
            myStringBuilder.AppendLine()
        Next
        Clipboard.SetText(myStringBuilder.ToString)
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image when the NX session terminates
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
        '----Other unload options-------
        'Unloads the image immediately after execution within NX
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
        'Unloads the image explicitly, via an unload dialog
        'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
    End Function
End Module
satsun
Re: Zmiana w Journal-u
Post napisał: satsun » 07 sty 2016, 01:46
Kod: Zaznacz cały
April 3, 2014
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Sub Main()
            Return
        End If
        Do
                Dim myPtVal As String = "X = " & objectpoint(0).ToString("N2") & VbCrLf & " Y = " & objectpoint(1).ToString("N2") & VbCrLf & " Z = " & objectpoint(2).ToString("N2")
                    Exit Do
                Else
                End If
            End If
        Next
    End Sub
    End Function
End Module
Spróbuj takiej wersji, też niezbyt znam się na VB ale powinno działać. Poinformuj w temacie o efekcie. Jak coś będziemy probować dalej.
devon58
Post napisał: devon58 » 08 sty 2016, 10:07
Dokładnie o to mi chodziło, dzięki za pomoc!
Wróć do „NX CAM/Unigraphics”
