Looking for Help and Spareparts TUB 32 -1000
seals76
Post napisał: seals76 » 21 gru 2012, 21:47
Hello together,
i´m Jens from Germany and need your help...
I have trouble with my TUB 32-1000 By.1966.
I both this machine in the last weeks and it runs till the working spindle stops complete untill the turning process.
Today i dismounted the Working spindle following the instructions in the documentation and in this forum, i found the problem.
Both plain bearings are damaged. (01-025-401-31a and 01-026-401-32a).
And now my questions, can anybody help me to find contact to MEX or can help me to organice 2 new bearings????
And also i need a copy from the Drawings, page 10 -10a - 11 , this is missing in my documentations.
I find a copy in an other part of this forum. https://www.cnc.info.pl/topics56/jak-wy ... t14607.htm
But the resolution is not so good....
I hope anybody can help me, and say thank you in anticipation.
cnc35
Znawca tematu (min. 80)
Post napisał: cnc35 » 21 gru 2012, 23:51
I recommend company with parts for many lathes on stock.
www.zwmix.pl
I bought several pieces from them and I'm satisfied from quality of parts.
dudis69
Post napisał: dudis69 » 22 gru 2012, 02:28
Hello seals76.
Bearings, or spindle slide bearings for lathe TUB-32...? :mrgreen:
Do not give up
http://allegro.pl/panewki-wrzeciona-do- ... 98068.html
If you have trouble finding "bearings" to your TUB-32,
i can help you to buy and shipping.
Write a private message. :wink:
Pozdrawiam Sławek
seals76
Post napisał: seals76 » 26 gru 2012, 10:49
Hello Dudis69,
first merry christmas and thanks for your help.
Yes i need the slide bearings from the picture in the link.
can you help me to buy this?? Or can i buy this and pay via paypal on this website???
is it also possible to change only the brass parts inside of the bearings or must i change both parts???
greets jens
