silnik SM-024-0035-TG
andysu
Post napisał: andysu » 20 sie 2006, 21:44
witam
posiadam dwa takie silniki
WARNER ELEKTRONIC MARENGO
SM-024-0035-TG
może ktoś posiada cos na tamat
gaspar
Post napisał: gaspar » 21 sie 2006, 14:39
Coś bliskiego modelem:
VARIABLE RELUCTANCE STEPPER MOTOR WARNER ELECTRIC #SM-024-0065 FK 4-phase 24 VDC 10 ohms per phase. 2.4 amps per phase. 24steps per revolution 15° per step. Running torque approx. 10 oz-in at 1000 steps persecond. Holding torque 6S oz-in typical. Dimensions: (exclusive of tach sensor) 2" dia. x3-7/8" long. Tach assembly adds approx. 2" to overall length of motor. Dual shaft: front 1/4" dia. x 1-3/16" long,rear 1/4" dia. x 3/4" long. Has square mounting flange with four 4X40 male studs on front of motor which iseasily removed if required. NOTE: Performance will vary with type of drive unit used. Step accuracy 0.33%non-accumulative. This motor has a built- in slotted sensor/tach wheel that gives one output pulse per revolution.This sensor is easily removed if desired. Stock #SSM9255
